Max70
- Joined
- May 30, 2021
- Posts
- 52
- Reaction score
- 4
So, I need a little feedback here as my mind is not at rest.
I just changed the thermostat housing to the aluminum one (which included a new thermostat and sensor) and the coolant to blue G-48 (as per my previous post about coolant)
Now my concern is that before changing these, I used to notice that every time I switched on my AC (which in turn switches the radiator fan on ) the temperature used to drop a little, so the needle on the temp gauge used to drop a little to the left. When I had my OBD plugged in this used to mark like 85C (185 F), but now on my first drive after the change, the needed remained stable in the middle with or without the radiator fan on. Unfortunately now my OBDII is not connecting to my phone for some reason, so I cannot check.
Is this normal, or is there something wrong? I was thinking maybe the new thermostat spring is still hard? or maybe there is some air trapped in the radiator, even though I tried to burp it as much as I could.
