Having service advancetrac intermittent? Airbag light on as well? 2014 GT 5.0
Jgt58
Just wanted to put this into the archive. I was having the horrid service advancetrac soon with the airbag light coming on intermittently. After hours of research , and checking all the fuses , all the fuses were good. But I did see on another source that even if the main fuse off the battery shows good that it could still be bad.
I took a leap of faith that that could be the culprit as it was 20 dollars. Well it worked. Drove 200 miles and not one warning light. So I think it worked. I'll keep you all updated.
Jgt58
Drove another 200 miles no issues still
Jgt58
Came back today. I suspect a battery issue as I had alot of corrosion around the terminals.
