High Fuel Rail Pressure
RGLL
Louisiana
My 2006 V6 with 162,000 miles (all stock), does the same thing and the PID values for fuel pressure will be about 10 psi higher than what you see on a physical gauge. The service manual states how the PID values are higher than a gauge. I have a fuel gauge plumbed into the fuel rail and when the engine is cold it reads around 30psi and my scanner will show 40 psi and when fully warmed up it will be about 50 psi on the gauge and 60 on the scanner. The pressure also fluctuates all the time around 3 to 5 psi and I think that's just the PCM continually adjusting the speed of the fuel pump.
RGLL
Louisiana
While diagnosing a hot start problem I had reason to test the fuel pressure at WOT several times and saw that regardless of what my scanner was showing while driving (about 60 psi) that when I floored it the pressure would drop to about 45 gauge psi and the limit according to the manual is 37 psi gauge. This was before I changed just the fuel pump motor to cure the hot start problem. You have codes for defective O2 sensors and that might be the problem. Hook up a vacuum gauge and check for intake leaks and also do a smoke test if you find that your vacuum is not good. Hope you get it running good.
FarrukhAnwar
Florida
Thanks for the response! I verified that everything in the fuel system is mechanically working properly by hooking up a physical fuel pressure gauge, using a multimeter on various components, and monitoring/cross-referencing the live data. The O2 sensor codes appear to be from an actual rich condition rather than from defective sensors. On a cold start, the engine temperature is cold, and the fuel rail temperature is cold, so the PCM asks for the regular fuel rail pressure of 40 PSI. No codes are thrown and the fuel trims are close to 0. However, as the engine heats up and the fuel rail temperature subsequently heats up, the PCM starts asking for more and more fuel rail pressure until the desired fuel rail pressure (and thus the actual fuel rail pressure because everything is mechanically working fine and is just listening to the PCM) reaches over 75 PSI, in which case, the High Fuel Rail Pressure code is thrown, and because of the high fuel rail pressure, the long term fuel trims become very negative at -15%, in which case the O2 Rich sensor codes are thrown.
RGLL
Louisiana
Do you have a tune? Perhaps that is why your fuel rail pressure is reading 75 PSIG when fully warmed up. Mine reads 55 PSIG when fully warmed up.
