T
TORMENTOR
Guest
And now I'm worried...
While installing my Steeda UDP's I could not remove my fan without having to unhook my upper radiator hose..... So. We tied the hose up to prevent fluid from leaking out and plugged the upper radiator bung with a plug from a plastic jug because I had fluid running all over the place.
Well to make a long story short I installed the pulleys, hooked up the radiator hose and started the car to make sure the belt was running true, all was fine.
So I drive home which is only 7 miles from where I did the work. and When I pulled into my subdivision I looked at my coolant temp gauge and it is pegging the red. I think to myself Oh crap you stupid idiot you forgot to take that freakin plug out didn't you...
Yep thats right.
I pulled into my driveway and popped my hood to find my coolant reservoir had popped the cap and I have coolant all over my nice clean engine. Not a problem I cleaned it all up.
Here's My question, I need an answer from a mechanic on the forums.
Do you think I could have screwed my engine up driving it 7 miles at 60 miles per hour? While driving it the gauge was reading where it normally does, but when I got home it was in the red...
I fixed my stupidity and haven't driven the car since until yesterday in which I drove it for about 20 minutes and everything is fine, I am not leaking anything and the temp gauge is fine....I am still burning off the antifreeze that I couldn't clean off though...
Yep thats right.
