Idler pulley not lining up...
Discussion in 'Department Of Boost' started by blacllkllsi, Dec 20, 2016.
  1. blacllkllsi
    blacllkllsi forum member
    311
    Figured I would post this here since I am still unable to post on the DOB forum. I am finally finishing up my install and did my first start up yesterday. All went well except the belt on this one pulley beneath the waterneck is hanging off the back of the pulley about a 1/4 inch or so. You can see the belt wobbling slightly after it passes the pulley. I was thinking of shaving down the spacer but am wondering what could cause this? I am running 3 76mm idler pulleys, 2 on the bracket and one beneath the alternator, and a 3in supercharger pulley. The pulleys look lined up otherwise. I am also getting this chirping noise, sounds like it's the supercharger.
  2. o2sys
    o2sys forum member
    4,366
    17
    The belt chirping is from misalignment probably. Smooth idlers are usually not the root of the cause but a grooved pulley usually is. What idlers pulleys are using (from what car?)
  3. Department Of Boost
    Department Of Boost Alpha Geek
    8,785
    Something is out of alignment if the belt is hanging off a pulley. Shaving a spacer down is a Band Aid fix.
    I locate chirping with WD40. It won't solve it, but it will narrow it down to exactly where it's coming from.
    You may want to try the DOB FB page in the future. A lot more DOB owners will see your posts:
    https://www.facebook.com/groups/1158405817571225/
    I'm killing the forum shortly.
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
