Lund Boost Box
Discussion in 'Mustang Chit Chat' started by JG-1, Jan 13, 2019.
  1. JG-1
    JG-1 forum member
    357
    22
    I’m having an issue with my Ngauge w Boost Box. I had my supercharger install done at Evolution Performance back in July, who also did a remote Lund tune and installed the boost box with ngauge. The analog signal on the Ngauge was reading 0 at idle, which I knew wasn’t correct, and brought the car back to Evolution. They ordered a new boost box and installed it yesterday. They did a vacuum test and said all is good. Now, the analog signal is reading -10ish at idle like it should be, and down to -12 when coasting at speed. The issue is I barely get a positive reading when I punch the throttle. The gauge will get down to 0ish and may go as high as +2 to +3, but not higher.
    Evolution says the Ngauge/Boost box was calibrated when they originally did the install in July.
  2. eighty6gt
    eighty6gt forum member
    2,970
    81
    Maybe you're making 3 psi
  3. JG-1
    JG-1 forum member
    357
    22
    I’m running around 12lbs boost.
  4. JG-1
    JG-1 forum member
    357
    22
    Lund Racing is letting me stop by tomorrow to get this boost box figured out.
  5. JG-1
    JG-1 forum member
    357
    22
    They couldn’t figure it out.
    Grrrrrrrrrrrr........
  6. 01yellerCobra
    01yellerCobra forum member
    1,833
    45
    My first guess would be a bad sensor. You said Evolution calibrated it when it was initially installed. Did they re-calibrate it after fixing the vacuum issue?
  7. JG-1
    JG-1 forum member
    357
    22
    No they didn't recalibrate after installing the new boost box.
    What sensor are you talking about?
    I drove up to Lund Racing today and Matt Honeycutt (he created the boost box) took a look at the setup and how it was installed and he confirmed it was installed and calibrated correctly. He put in a 3rd boost box to try and it's still not showing boost, only vacuum.
    He wants me to do some dataloging.
  8. RocketcarX
    RocketcarX 95% of my weight is fuel
    2,560
    140
    Throw in a cheap mechanical gauge to verify you are making boost
  9. JG-1
    JG-1 forum member
    357
    22
    Hi. The car made 801/650 at Evolution.
  10. 702GT
    702GT S197 Fanatic
    2,057
    49
    Did the dyno graph say 3psi (via sample port)? If it did, I would drop that all over the mopar forums and walk out.
    :troll3:
  11. RocketcarX
    2,560
    140
    Where is the sensor located?
  12. JG-1
    JG-1 forum member
    357
    22
    In
    lmao
    eighty6gt likes this.
