The only write-up I can find is with a guy wiring it up to switches inside the car as well so I'm a bit confused. I got the water pump with relay kit. I just want to wire it up the usual way. No extra switches etc.
I have the 2 black grounds going to a ground, the orange constant 12v power going to the back of the fuse box and on the positive post. I'm wondering where I should Wire the green "power on" wire to. And also if I still need to have that orange constant 12v wired up if I'm not adding any switches.
Thanks
Thanks
