I installed my pump the other day using the suppled relay kit. I also added a switch inside the cabin to run the pump with the car off. From the battery through a fuse wire and switch, I tapped the green signal wire to the relay. Now when I flip the switch inside the car the pump goes on and runs fine. My issue is when the green signal wire is hooked up to a key on power source through a fuse, the fuse blows when the key goes to on. When I attach the green signal wire to a power source without the fuse wire in there the pump runs fine. There is a bit of a spark when I touch the relay signal wire to a power source, but the pump whirs into action. What I can't figure out is I can power up the green signal wire to the relay via a switch and 30 amp fuse. I can power up the green signal wire by directly connecting it to a power source. But when I connect it via a fuse the fuse blows. I don't know why the switch works but not the key on power source with a fuse.
The only thing I can think of is the relay is drawing a bunch of amperage and the only reason why the the switch seems to work is the long length of wire running back and forth to the cabin is eating up some of the amperage and the fuse is staying intact. This seems kind of far fetched but I can't think of any other reason why I can't get this to work as it's supposed to. Below is a schematic of how I have everything wired up. Can anyone see why this wouldn't work properly. I would think that my added switch wouldn't work before the regular wiring wouldn't. I'm baffled.
