rayS197
LCA's and all??
He will never admit that swaybar delete is FTMFW!Wow, looks great!
Did the sway bar delete install go smooth? Were you impressed with how much weight you pulled off the front?
Ha ha you bastards! That sucker was heavy on my chest when I rolled the creeper out from under the car. The delete was like taking a pillow and bolting it up. Haven't driven it yet though.
Why not just go with a WOTBox? No epoxying or any of that, just splicing into the PCM wires and its good to go.I went with a RAM Powergrip HD and matching steel flywheel. No break in period required, so it's drive it to the track and let 'er rip. Line lock is going in as well. I'm researching the 2-step install a bit more, and if I figure out exactly what's needed (seems you need to epoxy a reed switch to the clutch pedal, but I've heard two different approaches), I'll take it to JJ's for a nice install--he has a real knack for clean electric work.
