Ok Im throwing code p0183,p0193,p0340 and p0344. I recently changed cams, went with larger turbo, went return fuel system and swapped from my 3650 to a 6r80. Before I made changes I never thru any codes. I know codes are related to fuel rail pressure and cam position sensor. My tuner believes they are on same circuit and maybe that could be a fuse. I checked fuses and all are good unless not checking right ones? Car drives but kind of goes into like a limp mode if get on it at all and dash reads - - - - where mileages would normally read. Any suggestions?
