psfracer
billy badass
First the easy stuff--some as previously mentioned:
75 shot, keep stock plug gap.
Verify bottle pressure is 950 psi. System will work terrible if only at 800 psi for example.
Check the ground for the fuel selonoid. Did you verify it is even opening? A week ground will cause the selonoid to not function properly. Sounds like its not when you mention hardly any fuel is coming out, and by changing the fuel jet it didn't make a difference.
Have you monitored your A/F while spraying?
Now, when I ran nitrous 4 years ago, with the stock converter, at 125, the converter would lock/unlock on the big end, causing the car to fall flat on its face. Is it possible that is what you are experiencing?
