1950StangJump$
- Joined
- Apr 1, 2010
- Posts
- 966
- Reaction score
- 108
Need some opinions on these options . . .
With my Moroso oil separator, it came with shitty, low pressure fuel hoses. When they get hot, you can clearly see them sucking shut under vacuum.
If I step up to high pressure fuel injector hose, they don't suck shut, but they are hard to work with; I am finding it almost impossible to get them fully on the barbs, and they don't cleanly bend around curves.
I can go back to the low pressure stuff and use an inner hose support spring . . . but only from the separator to the intake. The opening at the PCV on the valve cover is too large, and the spring would fall down into it -- so the spring is out for one of the hoses.
So, I thought I would use a brake booster hose. It is specifically made to not suck shut. But, I wonder if it will handle the oil okay? Obviously, it is intended for air and not oil.
Thoughts?
Thoughts?
