Bruce the 07806 is spec'd for the 01-04 cars, correct? Then you just need the proper throwout from Ford.
They're not even that expensive, it's what I plan on using.
It was professionally installed by a well known speed shop locally. I am not factoring that into my loss though I should. Pricing $699 for the clutch kit, $299 for the flywheel and 6.5% in sales tax was just shy of $1100 bucks. Neither was reused. However you did jog my memory that a friend I offered the flywheel to free of charge as I did the clutch to a guy in desperate need, gave me $40 for the flywheel in spite of my insisting he just take it off my hands and try to get some use out of it. So let me rephrase and say just over $1000 LOL!
I was bitterly disappointed because I expected "cadillac results" on what was supposed to be "cadillac quality". Every one raved about the clutch so I forked out the money and was it a major disappointment. To date the single biggest waste and loss on money spent I have experienced on a modification. To some that would be a blessing. To others that would be a big loss. For me it was quite a hit in the pocket book at the time.
I have used stock, RST, and RXT. I don't see the need for the RST. My RXT feels and acts the same but doesn't overheat at the strip. If you want a twin disk clutch and are thinking McLeod, go with the RXT. Pedal feel is like stock and I use the stock throw out bearing. It is best to use the McLeod flywheel (I have steel and that is what I prefer over any lightweight option). The stock flywheel won't work and you will have issues. I have one complainant (not counting cost) about the both the RST and RXT. My car is street driven and I get driveline vibrations caused by the clutch. I have seen only one seller mention this: http://www.jpcracing.com/mcleod-rst-twin-disc-clutch-kit-for-2001-5-2010-modular-ford-engines/ . They call them driveline feedback tones. I get that vibration listed in the ad. It is obnoxious. If you stay in that rpm range too long, you get misfire counts.
All of that being said, when this clutch wears out, I will be reluctant to try anything else for fear of high clutch pedal effort and strange engagement height.
What's the reasoning behind not being able to use the stock flywheel? Is it a dimension issue like mentioned above?The stock flywheel won't work and you will have issues. I have one complainant (not counting cost) about the both the RST and RXT. My car is street driven and I get driveline vibrations caused by the clutch. I have seen only one seller mention this: http://www.jpcracing.com/mcleod-rst-twin-disc-clutch-kit-for-2001-5-2010-modular-ford-engines/ . They call them driveline feedback tones. I get that vibration listed in the ad. It is obnoxious. If you stay in that rpm range too long, you get misfire counts.
