$500 shipped to lower 48. dr3z 12a650 ace.
Flashed with Crate_6 control pack strategy, no PATS to worry about.
This is a factory OEM part, without any modifications, PATS is intact.
The control pack strategy does not need a PATS delete to be done.
The control pack strategy is not EPA certified.
I can add:
Any CAI as long as it has a known flow sheet,
Gear ratios (trans, diff, and tire size) so speedo on 05-09 MYs will be correct.
Long tube headers, while not a "must tune" mod, there is a small tweak w/good results.
VIN can be flashed with Forscan if you so desire. I can add your VIN.
I cannot add for any other mods, Stock Gen 1 coyote ONLY.
I can add:
