Pinion Bearing Went Out
Discussion in 'Mustang Chit Chat' started by Tony Conti, Nov 4, 2020.
  1. Anti
    Anti forum member
    579
    234
    After more digging it looks like it was just a poor forum source, because trying to go back find it, I am finding other people talking about pushing 1,000 hp without issues
    raredesign and RED09GT like this.
  2. Anti
    Anti forum member
    579
    234
    I'm trying to see what 400 bucks more buys me vs the carbon clutch plates.
    Also, something to consider, being honest, I am hard on my car at times. It satisfys my itch to drive it like I stole it, regularly.. probably why the carrier and pinion bearings are screaming now.
  3. RED09GT
    RED09GT Senior Member S197 Team Member
    2,168
    249
    The CF clutches are not that much of an upgrade, they still only have so much surface area.
    I went with a Yukon Grizzly Locker and regret not going with the Truetrac.
    Do it once and go with the Truetrac, lots of satisfied customers out there.
    raredesign likes this.
  4. GlassTop09
    GlassTop09 Member
    347
    105
    Very interesting.................
    I found this link that does deal w\ the subject of TBR & diff carrier max TQ rating contained in an email conversation between a race car builder & a Torsen engineer (assuming that the builder was considering a Torsen diff for his racer). The product isn't the focus but the math concerning TBR & diff carrier max rating is the focus as that will be valid for any LSD diff. The reading above this email is the usual run of the mill stuff concerning LSD's & TBR but you may find it useful..........
    The only thing I haven't found yet is the actual max TQ rating of the Eaton Detroit Tru-Trac diff (1 w\ 3.5 TBR) to find what is the max engine TQ range (depending on car's 1st gear final drive ratio being used along w\ it's weight) that this puppy can hold........ Somehow I do believe it is >10,000 ft\lbs.
    http://www.carter-engineering.com/cerearend.htm
    Hope this helps.
    To the OP,
    Glad you found most of your noise culprit.
    Sucks that it entailed a $700.00 tire expenditure.
    I myself just went thru an exercise recently w\ my Stang that proved to me the amount of increased NVH transfer that can occur when swapping out parts that connect the rear axle to the unibody that can make the rear diff sound like it's having issues so I can relate.
    Which is a testament to just how solid this S197's unibody construction is..........
  5. Midlife Crises
    Midlife Crises Member
    611
    336
    I spoke with Eaton before I ordered the TruTrac. One of the things the Rep. told me was that the TruTrac is stronger than any of the 31 spline axles on the market so breaking the carrier is not a common occurrence.
  6. Anti
    Anti forum member
    579
    234
    Done deal. Thank you all for humoring me. And thank you to the OP. Glad you found most of the noise also. Hopefully this and all new bearings and seals solves mine.
  7. Greg D
    Greg D Junior Member
    16
    I had a shop install a 9" Eaton Tru-Trac in my '66 GT350, with 3.50 gear. The car has a Roush 342R motor that dyno'd 461HP and 420 lb-ft torque at the flywheel. During full-on acceleration, the car exhibited an extreme chatter that felt like the rear was going to explode until I coasted for 10-15 seconds. The shop loosened some clearances and it helped, but it will still do it once in awhile - again, only under very hard acceleration. With moderate acceleration, it behaves really well. However, I probably won't go with another Tru-Trac. Just my 2 cents.
  8. Norm Peterson
    Norm Peterson corner barstool sitter
    73
    3,309
    172
    What kind of clearances did they loosen up?
    Norm
  9. Norm Peterson
    73
    3,309
    172
    Thanks for the link. I've saved it to a Word file for ongoing reference. FWIW, I recognize the name of the person asking the questions from Corner-Carvers.
    Norm
  10. Tony Conti
    Tony Conti Member
    23
    81
    Anyone have links to those s197 suspension articles?
  11. Pentalab
    Pentalab forum member
    3,580
    402
    The oem LSD is junk. The CF version is also junk. The CF plates will melt. The oem rebuild kits are cheap, like $100 for the CF kit, but who wants to be rebuilding an OEM LSD every year or two ?
  12. Sky Render
    Sky Render Stig's Retarded Cousin S197 Team Member
    9,400
    323
    Tony Conti likes this.
  13. Tony Conti
    Tony Conti Member
    23
    81
    Sky Render likes this.
  14. Anti
    Anti forum member
    579
    234
    Call me late to the party, but it didn't click till I saw the "s197forum.com" decal...
    Sky Render and Tony Conti like this.
  15. Sky Render
    9,400
    323
    LOL
    Y'all should check out my build thread in the Corner Carvers' section.
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
