28One, I was reading through your other thread and am posting your directions so others can read it as well. I do have some questions regarding what an IPA or Eraser Wipedown is? Based on your notes I don't need them which is good news as I have no idea what they are...
Here is my process I used when I applied Cosmic to my GT:
1 – Wash
2 – Chemical Decon – CarPro IronX
3 – Nanoskin Autoscrub Pad (Claybar if you wish)
4 – Paint Correction if needed (remove swirls by compound or polish)
5 – Apply Invincible Primer either by hand or machine (No need for IPA or Eraser wipedown)
** If applying by machine, use polishing pad @ speeds 4-6 (I used Flex 3401 & LC White Hybrid) **
6 – Apply 1st coat Cosmic by hand or machine (No need for IPA or Eraser wipedown)
** If applying by machine, use finishing pad @ speed 2 (I used Flex 3401 & LC Black Hybrid) **
** If applying by hand, use supplied applicator and apply as if you were applying a wax **
** Wait 30 minutes then buff off residue with MF towel **
** If adding additional coats, allow 2 hours after initial application of Cosmic before applying second layer. Specific binding receptors ensure perfect cohesion. Layering must be done at this stage of the process. You cannot add additional layers 6 months from now **
7 – Apply 2nd coat Cosmic by hand or machine
If you don't need any major paint correction you may be able to skip the compound step, the invincible primer did a very good job of any minor items when i used it today.
