Reverse lit white v6 guage faces
Discussion in 'Mustang Chit Chat' started by Chistopher, Sep 10, 2021.
  1. Chistopher
    Chistopher Junior Member
    41
    Where can I find white guage faces for a v6 cluster? So that when I turn the backlight on, the white parts illuminate and the numbers stay the same
  2. 07 Boss
    07 Boss Senior Member
    3,109
    409
    What's the difference between the base and gt gauges? I can't ever remember seeing reverse lit gauges only overlays.
  3. Chistopher
    41
    gt has 2 more guages and the speedometer goes higher. If overlays work I'm fine with that too. I should also probably point out that it's a 07
  4. 07gts197
    07gts197 forum member
    1,115
    105
    Gts did not have more gauges, the 6 gauge cluster was a premium thing not Gt specific. I’m not sure anyone makes reverse glow gauges for these cars. The whole aftermarket for these cars has been drying up for some time.
  5. Chistopher
    41
    Are you sure? I have a premium and I only have gas and temp
  6. Chistopher
    41
    I may end up having to do that. I'd prefer it if I could get the white part to glow, but I don't think I'll be able to find anything.
    Is there any trouble with the white on white glow when it's getting dark, but not dark enough to have the headlights on?
  7. 07gts197
    1,115
    105
    I was wrong, it’s part of the interior upgrade package.
    As for your other question if the numbers get hard to see turn your headlights on.
    I have a white face overlay for my ac gauges on my 00 Gt. I only ordered them because the previous owner took out the original one and replaced it with a stupid looking white face overlay that was cracked and looked like crap. Anyway, the one I bought was one of those cheap ones off of eBay. During the day it looks good but at night it looks horrible. The quality isn’t that great. I’d expect overlays like those posted to be the same but it’s worth a try. Good luck lining it up though.
  8. DieHarder
    DieHarder Member
    585
    242
    There is a 6-gauge cluster for the V6. Speedo only goes up to 120. Got one for my son's car.
    If I were you I'd work on finding a 6-gauge cluster and my color controls/buttons. Since you have an 07 it should be plug and play. Was on my son's anyway.
  9. Chistopher
    41
    Doesn't a new cluster interfere with the security system and the chip in the key? That's what I've heard anyway
  10. DieHarder
    DieHarder Member
    585
    242
    Nope. Not in your case. 05 - 09 cars don't have cluster issues like the newer cars. I've switched out clusters on both of our cars (06 & 07). Was completely plug/play. No difficulties whatsoever.
    Chistopher likes this.
  11. JimC
    JimC Senior Member
    1,966
    276
  12. Chistopher
    41
    That's looking like a good buy, the picture they have on there looks good, but do they have any issues with aging or fitament?
  13. Chistopher
    41
    Also what's a good cost on a 6 guage v6 cluster? I'm seeing them for $140 plus I'm assuming I have to pay to reprogram the odometer
  14. Chistopher
    41
    and how much of a pain is it to reflash the ECU? For the mileage that is
  15. Chistopher
    41
    Last question, do they require a different bezel?
  16. DieHarder
    DieHarder Member
    585
    242
    That's probably about right. I wouldn't worry about reprogramming unless it's an issue. Not sure who can. I believe you can only advance odometers. Not retard. Others would have chime in on that.
  17. DieHarder
    DieHarder Member
    585
    242
    Never done that (reflash). Bezel is the same. Pop the old one out (4 screws & a connector on the back). Pop the new one in. About as easy a job as you'll fine on these cars. Takes about 10 mins if you're slow. About 3 once you've done it a couple of times.
  18. VGMStudios
    VGMStudios Junior Member
    29
    Check out blackcatcustoms.ca they make custom gauge faces.
    This is mine that I made myself with thier help. My car is a 07.
  19. DieHarder
    DieHarder Member
    585
    242
    That is different. Curious if you had modify the tune to account for the 200 mph speedo?
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
