Scuba-Matt
Boost freak
It's hard to tell from those pictures what the gap looks like since the detail is all lost in shadows. Did you ever run the springs before the struts, because that's what we're talking about here. People ran the springs on stock struts, and then switched to Konis which resulted in the front sitting lower than it did before. It's pretty well documented at this point that this will happen 100% of the time due to the physical dimensions of the front koni struts.
If you went straight from stock to this setup you probably wouldn't notice, because it has a rake from the factory. It's really obvious when you put Eibach's on first then switch to the Koni struts, since the Eibach springs level out the rake, and the Koni struts brings it back.
I changes the springs, struts and mounts at the same time. I'll try and get a better pic.
