Rick Simons
- Joined
- Sep 27, 2019
- Posts
- 250
- Reaction score
- 61
I currently have Prothane motor mounts installed, primarily to keep the headers from moving around and keeping one header tube from coming in contact with the steering shaft during hard right cornering and/or deceleration. For these they serve the purpose, and also improved the shifting as well. They have just one little annoying trait though- there is a harmonic that develops between about 1800-2000 rpm. Now it's not really that severe (the average person probably wouldn't detect it), but I don't want to think about the possibility anything vibrating apart under these conditions. I was thinking about removing the Prothane mount on the driver's side and installing the stock mount. I figured I might use the lateral rigidity of the pass. side Prothane mount to keep the header off of the steering shaft, and hopefully the different durometers would eliminate the harmonics or at least change the frequency/amplitude to something more livable. Has anyone experimented with mis-matched motor mounts?
