SoundGuyDave
This Space For Rent
- Joined
- Apr 9, 2007
- Posts
- 1,978
- Reaction score
- 29
You want to see some horsepower? Looks like this guy just mashes the gas and coasts the majority of the course....and is dominating: https://www.youtube.com/watch?v=KC1aRHekq8Y
Forced induction
2010 NASA Nationals final race... Onboard with Chris Griswold, who DID somehow manage to take the championship ;-) Chris is a great guy, one HELL of a driver, and he competes in my region, so I'm on track with him fairly regularly. As a matter of fact, I usually get passed by Chris. Twice. In a 35-minute sprint race.
Horsepower on that car is classified, but I am led to understand that he's running just under the X,XXX mark. At that point in time, my understanding was that the motor (347 stroker, LOTS of boost) would last roughly two races (not weekends, not days, races...) before ripping the head off a valve or two and ingesting it into the turbo, and requiring wholesale replacement. Since then, the wick has been turned down, as have the valvespring pressures.
Not to take anything away from Chris, but what you see out of his on-board is a little bit of non-parity. Chris is in the lead of the AIX field, so none of them in view, and is working through the AI field, which runs under a slightly different rule set.
AIX: Partial tube-frame conversions allowed, OPEN tire rule, wheel width limited to (IIRC) either 12" or 13" max width. Power is unrestricted. Again, IIRC, Chris was running 335mm Hoosier A6 on all four corners, with Tiger Racing aero bodywork and a G-stream wing. In comparison:
AI: Strict 9.5:1 weight-power rating, usually in the 340-370HP range, limited aero treatments, and max 9.5" wheels, with spec TOYO RA-1 tires, AKA "baby's first R-compound." Treadwear rating of 100, if that helps.
Also, he was doing FAR more than just "mash the gas, and then coast." Keep an eye on the friction-circle lower/center of the screen, and watch his braking, accel and lat-G numbers. A lot of the "coasting" that you see (and there was a fair amount) was due to creating spacing for him to make a pass on corner-exit. He would have to give up a tick of speed at entry to be able to take a very late-apex line, so that he could get straight, put the power down, and NOT track all the way out and hit the car he's passing. Much different driving style than most of us are used to. He's still pulling pretty consistent 1.3-1.4 lat-G (average, not peak!), but his goal is to get straight so that he can actually use the power he has. Without the turbo, he's probably making somewhere north of 550HP at the wheels. You can't have that much steering angle in when the power comes on. With the turbo, that power comes on like a grenade going off.
Another great in-car AIX video, this one of Paul Brown. I believe that setup was all-motor, running against Ernesto Roco's boosted Ford. If you want to get a feel for what driving one of these beasts is like, check out the restart around 4:00 in, and watch what happens after he tries to drop the hammer coming off the corner passing the Factory Five Cobra...
Fun stuff!
