Saleen blower VI throttle body upgrade
Davidx9x
Essex County, NJ
Anyone running a Saleen series vi for the 05-09/10 GT? Been looking to upgrade my throttle body. Is it worth it? You can you really feel the difference in power? If so when does imthe TB work best? Wot? Or through out the RPM range?
Thanks
mustang1200
Badass
I wouldn't waste the money upgrading the throttle body personally. If you do I'd make sure you stick with an FRPP unit. I don't have first hand experience with this as I avoided, but multiple tuners I've delt with said it was more trouble that it was worth. I was able to make right at 600rwhp and 620rwtq with my Saleen blower. If you want to do anything get the ported lid from JDM.
tigerhonaker
TN
Thanks
David,
Brenspeed was a very large dealer for Saleen when it was rocking and rolling.
Give them a call and ask to speak to George or Brent.
I ran the Saleen Super Shaker for years.
Terry
how much boost are you running?
pacettr
PJ Lover
Yukon, OK
I have the FRPP unit. No direct before/after comparison as there were a couple of other mods done at the same time. See sig.
Sactown
Sactown
Sacramento, CA
I ran the FRPP unit on my 06 with a Saleen blower, but you really don't need until you start pushing 500+rwhp, and even then it is probably not necessary.
Saleen304
My car with a Saleen blower made 560 rwhp on stock throttle body and when I went to the FRPP TB it made 610 rwhp on 93 octane. Worthwhile upgrade for me.
Davidx9x
Essex County, NJ
Well as of right now my setup stands like this: 3.4 blower pulley, 39lb injectors, high flow fuel pump, detroit rockers blower cams, kooks catted lts and 4.10s. I am running stock internals and i don't want to go over the limits, keep in mind that i am near border line. Thanks terry, i am currently running a 93 octane brenspeed tune
With this setup i am running around 7lbs of boost +/-.
Question getting a ported lid; is any low end torque lost?
50hp after a TB upgrade?!? That's insane!!!!
quiksilver15
Houston
If you already know you are at the borderline, why mess with it? Are you prepared to build it if it blows? Just wondering.
7 psi.... a TB is a waste of $$
Saleen304
I couldn't imagine the TB is the bottleneck at 7 psi. I would recommend spending the money on chassis and suspension upgrades. You can shave some weight off the front end with a BMR k member for the price of a TB.
Davidx9x
Essex County, NJ
Not so much a waste of money. it was a trade of a few parts on both sides, the amount i spent was very minimal.
The psi i should be running is around 9. With the mods i have, as you guys can imagine, the psi is a bit lower
Sactown
Sactown
Sacramento, CA
IMO leave your setup as is, once you have a built motor get the TB
Davidx9x
Essex County, NJ
i have been told, but as of right now since my car is a DD the build is nowhere near the future. Otherwise i'd be looking into 10% OD balancer or smaller blower pullies. Thanks for the advise.
