Sequential turn signals
Discussion in '2005+ Ford Mustang v6 4.0L Tech' started by Dwain Pate, Sep 13, 2019.
  1. Dwain Pate
    Dwain Pate Junior Member
    9
    Hi all. I have a 06 base that I installed sequential wiring kit. They blink faster than I would like. I realize the flasher is integrated in the SJB. Does anyone know if dealer can change the speed to have a little longer pause between flashes?
  2. MADGT
    MADGT forum member
    1,201
    14
    I suspect the speed is dictated by the aftermarket type/model of sequentials you installed; doubt a dealer would even touch them,but the some guru chime in
  3. Dwain Pate
    9
    Thank you.
  4. nfrizell
    nfrizell Member
    82
    37
    Led bulbs by chance?
  5. Dino Dino Bambino
    Dino Dino Bambino I have a red car
    56
    875
    124
  6. Dino Dino Bambino
    56
    875
    124
  7. 08MustangDude
    08MustangDude Resident Fuktard
    308
    31
    Blink speed is an "on-off" per second, repeat. If it's faster, then it things a bulb is out.
    Mine are all LEDs, no hyper-flash either...
    This is how fast sequential signals run on the S197s
  8. Iceman62
    Iceman62 Bullitt 6005
    668
    88
    OP; Where did you buy the kit & who's the manufacturer (make/model/part)?
  9. Dwain Pate
    9
    Not led. Thanks for responding.
  10. Dwain Pate
    9
    Hi Iceman62. It's a Drake 5R3Z-STL.
  11. Dwain Pate
    9
    Hi Dino Dino Bambino. Mine seem a tad faster. I can live with it. Just liking the speed of the later models. Thanks for responding.
  12. Dwain Pate
    9
    Hi 08MustangDude. Thank you for the info. I'm thinking of changing to leds.
  13. 08MustangDude
    308
    31
    Yours are not blinking any faster; from ON to OFF. The sequence may be faster,
    but from ON to all three OFF, it's the same.
