LordBritish
- Joined
- Apr 9, 2009
- Posts
- 315
- Reaction score
- 0
I have an 05 GT with a Shaker 500.
I've been having battery problems for a while and a few times I've been unable to start the car.
I've even replaced the battery with an Optima Yellow Top.
However, yesterday, when I started the car I heard that tell tale click-click sound. It still fired up but I knew it wasn't healthy.
I got my trusty Radio Shack Multimeter and the battery measured 11.5v at idle - too low. I then measured the voltage when the car was running. That measued 13.5+. That seemed normal enough so it did not appear to be the alternator.
Next I started measuring the current draw when Idle - it read 1.3A !!!!
No wonder my battery was draining !!!
So I started pulling fuses from the fuse box. I tried various fuses but when I pulled the radio fuse, the current draw when down to a normal 150 mA. I put back the fuse and it read 1.3A again. Repeated the test until I was satisfied - it's the Shaker 500 POS !!
I've already read that if you don't turn off the Shaker 500 when you shut off the engine, it'll still draw current but turning it off didn't help, it's still drawing about 1.2A.
For now I'm driving around with the radio fuse out. I can't use my Shaker 500 but at least my battery won't drain.
But I still don't know what's wrong or even how to fix it. I just know that's it's the Shaker 500
Any ideas folks?
Any ideas folks?
