spark plug socket issues 2006 Mustang GT
Discussion in '2005+ Mustang GT 4.6L Tech' started by EGAZ, Nov 21, 2021.
  1. Juice
    Juice forum member
    3,325
    1,163
    I used impact guns to disassemble and reassemble stuff that are clearly in the "Do not use impact gun" territory. It is not the impact gun that does the damage, it is the user. Short bursts is all you need to losen the stubborn fastener. If you are going to sit there and hold the trigger until something gives, well, that is not the use of the impact now is it? Using the hammering effect also helps with NOT rounding off bolts and nuts. And finally, noone mentioned the size of the impact gun. For plugs, I would reach for my 3/8" butterfly impact. Not the 1/2" gun I use for lugs, suspension bolts, the big stuff.
  2. Daniel Roberson
    Daniel Roberson Member
    115
    102
    One shop I went to complained that they couldn't get them out of my 2005 Mustang. I heard they changed the way the plugs were in the 2006-2010 Stang because of the problem. I used to get a ticking noise with my old set-up but now with the Supercharger with cold plugs I hear no tick. Don't mean to steal your thread but do you think the noise it made had something to do with those hot sparkplugs down in the engine?
  3. msvela448
    msvela448 forum member
    333
    124
    2008 was when the plugs were revised.
    Sent from my SM-N986U using Tapatalk
  4. MrBhp
    MrBhp Member
    669
    466
    Exactly how you break a two piece plug.
    I've R&R'd well over a hundred sets of these fragile things. With all the care in the world I would still break a few, more than occasionally. And then I saw an old timer mechanic, one of those we call a "shade tree" mechanic, change plugs on a 3v using a small impact. Since I switched to that method I haven't broken one.
  5. 07gts197
    07gts197 forum member
    1,158
    117
    Since everyone is throwing their two cents in I might as well too.
    I changed the plugs on my 07 in 2015 with almost 100k miles on it. I didn’t use any penetrating oil, warm the engine or an impact. I used a 30” breaker bar that’s it and only 1 broke. I’m sure no matter what I did it still would’ve broken anyway. I had a guy ship me the Lisle tool on another forum from the east coast to have on standby and I was glad I did.
    Just as important though is correctly torquing the new ones. Originally I used the “goodntight” method. It ran kind of funny but didn’t tick around the plugs but I got a torque wrench anyway and tightened them down to spec. All good ever since.
  6. EGAZ
    EGAZ Junior Member
    I have been out of town for the holiday weekend and am now on my three day RN travel gig in Kingman, AZ so I haven't replied recently. I have to say thank you to everyone who answered my questions and provided some insight and solutions to this problem.
    I have cleaned out the plug wells with Gumout, and a small coarse brush. All clean and shiny. Now to warm up the engine, remove the coil packs, spray PB Blaster and let is sit for a few hours to allow the penetrating oil to do it's thing. Then time to replace the coil packs and rewarm the engine. Then I will work with a lighter, 3/8 inch impact driver. I concur with the comments regarding the effect of the impact is to shake loose the fastener by using short bursts. I have used similar techniques over the years in working on a number of different machinery.
    I have some anti seize compound however one of the videos mentioned nickel anti seize. Is the nickel anti seize needed or does normal anti seize do the trick? Dialectric grease on the plugs then install them.
    This is my project for Tuesday afternoon when I return home from my 3 day 7p - 7a shifts. Let the PB Blaster do it's thing overnight.
    Thanks again for all of the ideas, suggestions, and support.
    I will take a few pics or shoot some video of the project.
  7. DieHarder
    DieHarder Member
    692
    280
    Nickel anti-seize; Do not use dielectric grease. (That's for electrical connections). Also, would recommend using carb cleaner; loosen plugs at least a 1/4 turn and spray into the plug wells. You want something that will break up/eat the carbon.
  8. skwerl
    skwerl tree hugger
    15,859
    765
    The plug issue was resolved in 2008. Unless the plugs in his car are 13 years old, then he's not going to break the plug in the head. Move on already, people. The 'plugs breaking in half' issue is over. There might be 5 cars still on the road today with bad plugs in them. Give it up already.
  9. msvela448
    333
    124
    Ummm... I don't agree. The heads were re-designed in 2008... But all 2005, 2006, 2007, and some early 2008, 3v 4.6L Mustangs would still have the old heads, with the old design, and if the owners never replaced the plugs with a one-piece design (like Brisk Racing, or AutoLites) then there is a good chance of there being the old 2-piece plugs in there. Especially if the owner adhered to the recommended 100,000 mile change interval.
    Daniel Roberson likes this.
  10. Jack F
    Jack F Member
    70
    34
    I have to agree. Especially when you consider the 5.4 3V. Fleet operations weren't going to buy some off-brand crap. It was Motorcraft or equivalent.
  11. EGAZ
    EGAZ Junior Member
    UPDATE: I forgot that my son is a Ford dealership service advisor. He will ask one of his techs the best method for me to remove my plugs.
  12. Jack F
    Jack F Member
    70
    34
    Glad to hear you're bringing in the brain trust.
    stkjock likes this.
  13. Juice
    Juice forum member
    3,325
    1,163
    How can you forget that? :lol: I bet the tech will tell you to use impact driver.
    MrBhp likes this.
  14. Daniel Roberson
    115
    102
    Everybody acts like a jerk here, why? Geez is it hurting anyone to ask questions? If you don't want to read it then don't otherwise the people who are interested should be able to. Like what is the big deal?
  15. 07gts197
    1,158
    117
    I think sometimes some of us can be jerks here but this thread was civil. People were giving him good advice and opinions.
  16. stkjock
    stkjock ---- Madmin ---- Staff Member Administrator Super Moderator S197 Team Member
    39,604
    2,487
    :lol:
    damn newbies... :cheers:
    skwerl likes this.
  17. Juice
    Juice forum member
    3,325
    1,163
    Are you referring to me?
  18. Daniel Roberson
    115
    102
    No, the Squirrell guy.
    MrBhp and skwerl like this.
  19. Forty61
    Forty61 forum member
    589
    347
    My ‘08 has the old design heads on it and I need to do my plugs. I am unsure when they were last done, probably never. So make that 6 cars on the road with bad ones!
  20. Juice
    Juice forum member
    3,325
    1,163
    Ok, just checking. :)
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
