Suspension ideas?
OX1
Jackson, NJ
"Increasing anti-squat" is about improving initial launch bite, and what it amounts to is intentionally changing the side view geometry for that purpose r
There's a catch to how much anti-squat you should build in if it's a street driven car. It's possible to overdo things for the straight line to the point where the rear axle becomes oversteerish in nature, which can make for a rather unrelaxing (possibly "exciting" and not in a good way) drive.
Norm
Thanks Norm for the explanation. I more or less understand the concept. Was just curious if anyone on here had done the reloc's on a stock height car, specifically for bite. I guess most don't bother with them unless they are lowering the car. For as cheap (and adjustable) as they are, might just slap a set in and see what happens. Kind of have to wait until spring now though, since I run a DR in the summer.
Norm Peterson
corner barstool sitter
RIP - You will be missed
I'm pretty sure that some have.
I suggest not going to the most aggressive (lowest holes), certainly not right away. Roll oversteer + sudden emergency swerve or getting caught in the rain sounds like the kinds of excitement most of us could do without . . .
Norm
The BMR LCA relocate brackets allow for a 2-3-4" drop at axle end.... pick one.
Norm Peterson
For stock height - start with 2" and just drive it a while. Carefully work down an inch at a time (and drive it at the 3" level for a while) only if 2" isn't working well enough.
Norm
