Tire Question
Discussion in 'Drift Racing Tech Discussion' started by Menes06GT, Apr 16, 2012.
  1. Menes06GT
    Menes06GT forum member
    396
    Im planning to buy a set of crap wheels and tires to use for my first up coming event and found a set of 17inch stockers. Two of them have the stock perelli's but the other two have michelin run flat tires 245/45R17 pilot sport a/s. I don't know much about run flats or there compound besides that they just have a very strong sidewall. Will run flats give me problems, could I run them on the back or just the front? All help is appreciated as I wanna get a set of wheels ASAP.
    Also looking at a set of stock 18inch 2010 Fusion wheels, I'm pretty sure they will fit but not 100% if anyone else knows
  2. HellsBells
    HellsBells 620/677
    5,576
    9
    You can run them on the rear!
  3. Menes06GT
    396
    Just to let anyone know who is curious I do not recommend run flat tires for drift use. The Michelin run flats I used were horrible and did not respond like normal tires once heated up.
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
