pass1over
I like it LOW
Ever since I put long tubes on my car and had AM adjust the tune, I have been having an idle issue that I can't figure out and they can't tune for. I just want to make sure I'm not overlooking something mechanical on my end.
While driving, if I push the clutch in the car will idle down to around 800 or so, then fall to 500 for a little bit, can hear/feel it struggling, then bounce back up to 800/900. It doesn't do it all the time and is worse when engine is cold.
I have cleaned throttle body, MAF and air filter multiple times. I replaced all gaskets on the CAI and replaced the breather tube from drivers valve cover to CAI. All clamps are tight and sealed. What else can I look at or is this a tune issue?
