Yes sir it ran better than most would think....never set off any codes, none, nada, ziltch. No flashing MIL's to indicate dead misses that would've triggered the PCM to do FSO on the missing cylinder(s) to activate COT protection. Car idled OK & would actually run Ok until you actually pushed it (load% up high enough to force the spark to break\blow out). Testament to just how strong the FoMoCo coils are & as long as the spark energy goes thru the plug wire core & past the core resistor the PCM can't determine that the coil\plug misfired (PCM uses 2 PID checks instead of 1 to determine a real misfire, 1 PID is checking the CKP sensor only for relative CKP velocity pattern fluctuations across all cylinders, 1 PID is checking the coil\plug thru the primary wiring during dwell\firing\secondary burn pattern as you would see under an oscilloscope trace....for a true misfire to occur BOTH PIDs have to agree, if the CKP shows a velocity variation but the coils\plugs dwell\firing\secondary burn pattern shows no misfire then the PCM records the variation but also records no misfire, thus why the 65,655 CKP threshold as more than a plug misfire can cause a CKP velocity variation to occur....such as varying AFR from slow O2 sensor feedback for an example). Also keep in mind that a 4.6L V8 by definition is a low compression engine vs a Coyote which is high compression...easier for a bad plug to still fire under low compression.......Question: Did the car those plugs came out of actually run???
Was this a truck by chance? I have been told some ford trucks do not set misfire codes for some reason. Thats what my inspection station told me about my van. Must get tailpipe sniffer test if not exempt. Which sucks, as noone has the old machines. Well, they are around, but not functional. So I must keep mine exempt.Yes sir it ran better than most would think....never set off any codes, none, nada, ziltch. No flashing MIL's to indicate dead misses that would've triggered the PCM to do FSO on the missing cylinder(s) to activate COT protection. Car idled OK & would actually run Ok until you actually pushed it (load% up high enough to force the spark to break\blow out. Testament to just how strong the FoMoCo coils are & as long as the spark energy goes thru the plug wire core & past the core resistor the PCM can't determine that the coil\plug misfired (PCM uses 2 PID checks instead of 1 to determine a real misfire, 1 PID is checking the CKP sensor only for relative CKP velocity pattern fluctuations across all cylinders, 1 PID is checking the coil\plug thru the primary wiring during dwell\firing\secondary burn pattern as you would see under an oscilloscope trace....for a true misfire to occur BOTH PIDs have to agree, if the CKP shows a velocity variation but the coils\plugs dwell\firing\secondary burn pattern shows no misfire then the PCM records the variation but also records no misfire, thus why the 65,655 CKP threshold as more than a plug misfire can cause a CKP velocity variation to occur....such as varying AFR from slow O2 sensor feedback for an example). Also keep in mind that a 4.6L V8 by definition is a low compression engine vs a Coyote which is high compression...easier for a bad plug to still fire under low compression.......
Actually ran on all 8 cylinders......only clue that showed any insight to this was the Mode 6 Self Check misfire monitor last count data & a FORScan idle data log showing STFT's adding fuel once PCM went into CL from OL (which is wrong since in OL PCM is applying fuel enrichment so STFT's should've went - instead of +) & bouncing LTFT's across both banks (which is also wrong, LTFT's should be static)...but the Mode 6 numbers never counted past 10-15 counts on any individual cylinder during any completed drive cycle & all cylinders showed some count variation between 1-15....not near enough data to isolate bad plugs since other issues can cause this exact same pattern...like slow, erratic O2 sensor feedback causing fluctuating AFR. I have data posted in another thread to show all this in more detail.My car was built 8/11, so RA says I should use DY1185 instead of DY1165. They're only $79/each and the Bosch 17321 is $54.
I have heard the idea that the o2's that Bosch makes for Ford might be tighter specs/tolerances than what they would sell under their own name brand. $50 total difference in price, guess it's not really that much.
Man, those plugs are beyond gone. Running on only 3 of the 8 cylinders huh?
Nope, it was my '09 Mustang GT w\ it's 4.6L V8 in NA trim w\ some mods....no truck version of 4.6L V8. It was thru using FORScan software that I discovered this was the case w\ my car's PCM concerning the misfire strategy. Now my PCM will set misfire codes but the P030x DTC's are only set due to excessive CKP velocity variation pattern vs the other cylinders pattern comparison only, NOT necessarily due to an actual coil\plug misfire. So when you see these P030x DTC's don't just assume that this is only plug related (injectors, wiring including bad grounds, PCM drivers, valve train components like failed cam followers\lash adjusters or leaking valve seats, coil springs\boots, O2 sensors, failing CKP sensor, loose CKP trigger wheel, bad harmonic balancer, bad alternator, etc can set off CKP variation offset patterns as well....) just because this data is labeled as "misfire data". Been here, done that........Was this a truck by chance? I have been told some ford trucks do not set misfire codes for some reason. Thats what my inspection station told me about my van. Must get tailpipe sniffer test if not exempt. Which sucks, as noone has the old machines. Well, they are around, but not functional. So I must keep mine exempt.
No it doesn't clear them...it will never actually count them until the MM 60-40 DFCO training has successfully completed. PS--this is the training that the PCM uses to learn the CKP trigger wheel & any normal CKP variation between applying load% vs engine pumping variation during non combustion so engine can't be misfiring while performing this training. I know you know this but putting this here for info purposes. Also just remembered that when a KAM reset is done on a SO PCM, this data in Mode 6 is cleared....any data that is in Mode 9 or 10 is still there......but most can't see that data unless using something such as IDS....So the misfire monitor relearn clears misfire counts? Cause I have not found a way to clear those. Not even an IDS complete reflash lol.
checked my scanner again, there are two sets of o2s to monitor
These two are in volts
O2B1S2
O2B2S2
These two are in mA
O2S11
OSS21
I know the S2 are the downstream NB's, but why are the upstream ones read as mA? I'm assuming those are the upstream ones.
Watched my STFT1 and STFT2, neither stayed at 0. You say a few %, what variation is acceptable while driving, idling, etc?
LTFT is not bad at all. I have about the same b1 to b2 difference. Overall the tune is on the rich side by a few %. No concerns there.LTFT's did change, more slowly, as they should. They were always a negative number, and something that I thought was weird was that B2 was always half of what B1 was. so, B1 would be -0.830, and B2 would be -0.415, for example
