2mchtoy
addicted to speed
First off, I did a massive search and found a couple of things but to no avail. After I finished the build, it fired right up, ran really rich as I had 60# inj. in there and the tune told the computer I had 39# from the procharger tune. But besides that, I sounded awesome and idled good. Now the problem comes: I took off my intake to put my temp. sensor back in, and when I replaced my intake, I got one of the cop plugs(last one one on the pass. side) caught under the intake and ripped it off. So I replaced it. All seemed good, I went to fire it up and I get this clicking noise from the t/b and the car goes into failsafe mode. When I unplug the the plug going into the actuator it stops clicking and comes out of safe mode as I hear the fuel pump kick in. I get all these codes for the t/b acuator, 2100,2104,2107,2110. I have checked all the fuses in the kick panel, and under the hood with the relays. All look to be good! checked for crimps in the electrical lines, nothing. I end up buying a 62mm t/b from ford and get the adaptor so no problems with the butterflies. So the tps is new. I re-pinned the connector to the actuator. Nothing is helping. The only thing I have noticed is if I pull #19 pcm- out it stops clicking and If I pull #23 out of the relay box under the hood It stops, but is kinda warm. I have replaced them both of them with other fuses and relays and nothing. *Pulling hair out what little I have left* Voltage reads almost 5volts at wot. the only other thing I did after all this started was replace the 60# inj. with the stock ones and load up a modified stock tunes just to get it running, well that had no affect. Ideas? Match? gasoline? what do you think?
