Have you ever baselined the car before?
If so, what have you changed?
Do you have a pro charger hanging off the left front of the engine?
How much lighter was the battery that you swapped in?
You added Brembos, so that’s approx. 40lbs added, they are heavy compared to stock.
How much fuel was in the car when BL’d compared to this scaling? Always try to scale with the same amount of fuel. Make that amount the amount you plan to race.
So, your front to rear % look pretty normal for a street car with not much suspension work done. Left front is always a little heavy.
Front 56.2%
Rear 43.8%
Cross LF - RR 52%
Cross LR - RF 48%
You can change cross weight %s by adjusting suspension, you cannot change front to back %s by adjusting suspension!
Cross weights are 4% different, I’d try to close that up by up to 2%.
I’d try to lose front weight or move some to the rear. I’d like to see 46-47% rear or higher. But, to get higher than that your gonna start cutting and moving a lot!
Remember this, if you remove 15 lbs from the right front you won’t necessarily see a 15 lb reduction on the front of the car, unless it is in front of the front axle. And it may change the difference between the left and right by more than 15lbs. Any time you remove or move weight you have to adjust all 4 corners to get the %s back to optimum, once you find where the car is comfortable and fast for you.
Keep records of every change!
