WELDING AND USING A PLASMA CUTTER
GtTom
iS UNHOOKING THE BATTERY ENOUGH, OR DO i NEED TO UNPLUG THE ECM AND IS THERE ANYTHING ELSE TO DO BEFORE CUTTING?
01yellerCobra
San Diego, CA
When my buddy and I weld on a car we usually just disconnect the battery. Nothing else.
Sent from my SAMSUNG-SM-G935A using Tapatalk
mrt2you
new berlin
i am a bodyman. i weld on cars almost weekly.
when you say welding i am assuming you mean MIG welding.
disconnect BOTH cables and you will be fine.
if you are welding really close, 6" or closer, to electronics remove them before welding.
if welding close to wiring try to move it at least 6" away. 1' would be better.
