Shotokan1509
CT
Learned that I CAN get the car on the ramps without helper boards if I use the lip of the garage for the angle. I also learned this means I can not get out the drivers door with the car half in the garage.
JoshK
Modder AKA Fuel
Nebraska
Went out to the garage and looked at it in pieces. Returned to the house with a frown on my face.
Powered by Ford
I thought it was best to mount the wideband in the h or x in your case. Your only going to be reading one bank of cylinders with it mounted there. Am i wrong on this?
Hi jewc75,
No, you want it as close to the manifold as you can but too close can be too hot and damage the sensor. Typically just after the collector is ideal. If there are cats, you definitely need the sensor in front of the cats. On the 4.6 3V, it is better to mount the sensor in the driver's side which tends to run slightly leaner.
FalconGTHO
The Reporter
Scorpion Gulch
Mach2burnout
05 Redfire GT
Central Louisiana
Ahh the things we put ourselves through just to lay under our............cars.
Sounds like remodel job is needed to widen that garage door a little. lol
Newman
sumidicsayhuh?
Houston
Put my lower control arms on and new rear shocks off a 2012 5.0. And put 305-35-20 Nitto 555R's yesterday...
08StangGT_CS
San Antonio, TX
Installed the FRPP P Springs:
Was a little dissapointed. Couldn't tell the difference. I'm afraid of going with a more aggresive spring though.
Mach2burnout
05 Redfire GT
Central Louisiana
washed it and my F-150, tried to load it on my trailer to go to auto x on Sunday(oh hell I guess it is Sunday). Wouldn't go on my trailer, borrowed one and still spent several hours modifying ramps, etc to get it loaded.
Mach2burnout
05 Redfire GT
Central Louisiana
Went auto xing today. It was my first time and had a blast. A lot different than other forms of racing I have done in the past. Did ok though.
BruceH
BBB Big Bore Boss 322
Reloactaed and replaced the coolant tank with a Canton Vortech style. Mocked up tubes for a blow through. Cut the holes for a bov and maf flange.
A mondo bypass really is mondo big.
JEWC_Motorsports
S197 Junkie
Texas
Did this rendering using Fords website. This is the look im going for, except using the silver sve drifts and lowered.
