Idk if you followed my posts. Basically for the Conversion I built my own wiring which just plugs into the OEM car harness and uses the original Housings and a Raxiom Sequential Harness.
With normal lights on all three light up red but dimmed like the normal 7W haogen light, with turn signal on I have a Yellow Sequence going from the inner to the outer and for brake lights the middle and outer lightup overriding two of the three turn signal lights because both turn and brake need to work at the same time. Now the problem I'm having is the LEDs currently installed fitting for th original 3157 socket have a delay from Yellow to red so they don't light up red inbetween the turn signal lights pulses, wich is not good for brake lights. otherwise they are PERFECT. so the outer and middle chambers are currently disconnected and only the inner most chamber flashes yellow until I can find other LEDs like the ones I already have that don't have that delay.
Probblem is no one makes exactly what I need. Either brightness is to low for brakes or it has that delay or the are white and amber which makes the red lights color kinda weird for me. just always one thing.
The end goal is still a plug and play no wires cut solution thats clean, reliable, looks good and doesn't even throw any DTCs (last one I'm still fighting a single code)
Plus later on I'll try to somehow get a halogen look light to come out of the front amber parking light housing so I can put them back on and have my front side markers back
