Windsor Swap K Member?
SatinSilverStang
Chicagoland Mustang Club
What is the consensus on K-Members for putting a windsor based block in a 2006 these days? Appears the BMR is discontinued from my findings so what else is out there?
Bardstown, KY
Putting a 302/351W into a s197 is easy.
I have made 2 types of mounts for the stock k-member..
The 1/4 inch flat stock plate versions ( top pic ) were much better.
They adapt to the stock s197 motor mounts and the oil pan clears the steering rack.
I have a AJE k-member and have weighed it up against the stock k-member. There is only a 10 lbs. difference. ( as seen in the pic )
As a side benefit, the stock GT 4.6 dual exhaust lines up with the sbf Fox shorties
289S197
Cleveland OH
Is that using a t5 and stock transmission mounts, I'm planning on doing this with my v6 and it looks like the oil pan won't clear. Is the GT k member different from the v6?
