Wiring harness connectors
TexasBlownV8
Formerly TexasBlownV6
Central Texas
Various engine wiring harness connectors for sale, from a couple of harnesses.
Generally includes 12" of wire where it was possible and practical in removing from the harness.
Some of the connectors available include:
- automatic transmission shift range (DTR) and signal connectors (the round one and rectangle one) - $14 for the round one, $10 for the rectangle
- transmission sensor 2-pin connectors, 3 of them on an automatic ($5 each)
- throttle position sensor (TPS, 4-wires: YE/WH,BK/LG,RD/LG,GY/WH ) - $10
- fuel rail pressure sensor connector - $10
- alternator 3-wire connector - $7
- fuel injector connectors $6 each (only 6 are left/available)
- C110, square-ish 12-pin power connector for 2005's - $12
- BEC connector, no wires - $6
- pcm connectors - the larger one and smaller one, for 2005/2006 automatics - $10 each
These don't fit my 4.6L, so I think they're for a 4.0L/V6 (based on wire colors and number of pins):
- thermostat/temperature sensor connector - $6
- crankshaft sensor connector - $6
- cam position sensor connector - $6
- ignition coil pack connector - $7
- heated PCV connector - $4
- power steering sensor connector - $5
- a/c line pressure connector - $6
Shipping is $2-$6, depending on connector(s) and size.
zuritausmc
I love Red Bull
Escondido,CA
Would you happen to have the plug the goes into the top of the fuel pump hat? If so pm me the price. Thanks
TexasBlownV8
Central Texas
The only non-engine plugs I have are one set of side marker light connectors, both the larger and smaller bulb. Nothing for the fuel hat, sorry.
Taxman
One foot out the door
DFW FTW
I need the MAF plug that plugs into the throttle body.
5.0H
Connecticut
Plugs for GT fog lights?
Edit
Just saw this. Disregard my request then. GLWS
randys06v6
Edit
Go to advance auto parts. 13 dollars for 2 plugs a.k.a. Pigtails for the gt fog lights. I just finished making my own fog light harness.
They are high temp headlight sockets
Fits 9005 high wattage bulbs (which are gt fog lights)
Part number for it at advance is 84792
TexasBlownV8
Central Texas
MAF plug plugs into the MAF sensor. Throttle body connectors use different plugs.
Which one do you need? The MAF sensor plug is not available.
Both throttle body plugs are available.
Taxman
DFW FTW
Man I'm not sure what you call it. It's the plug that plugs into the throttle body from the MAF. It's on the driver side of the tb. I broke the tab when I did my cam covers last week and just stuck a little shim in it to hold it tight. Not an emergency, but if you got one, I'll take it off your hands.
TexasBlownV8
Central Texas
OK, so one of the throttle body connectors. How many pins does that one have? I have both, just want to make sure you get the proper one. Wire colors can help, too. Or a pic. (With my TB removed and replaced with a KB TB and relocated, I need to make sure you're getting the proper connector.)
lphegner
PM sent on cam sensor plug. Also wondering if you have an HID relay box.
TexasBlownV8
Central Texas
No HID stuff. PM replied to.
Posting a pic of where it needs to connect or what it's replacing will ensure I still have it and make sure you get the proper connector :)
TexasBlownV8
Central Texas
PCM connector pigtails, the single wires removed from PCM connectors with the square pins and 1-3' of wire, are also available.
Many of the connectors still available, too (not all of them in the original pic are available).
Hawgman
THE fucking bad guy
Texas
How many of the injector connectors do you have left?
