Andrey Sidorov
Hey fellas, i think it is not a surprise to anyone that stock s197 brakes are as* to say the least. So if you were thinking about upgrading your stock brakes to something better and not sell your kidney in the process or your calipers got bad and you need a replacement or rebuild - this will be the best route without selling any organs . So lets answer all the questions that usually come up and also at the end decide what we can do with the rears as well!
Question 1: 'Do I need any modifications or brackets for 6 piston fronts?'
Answer: Once and for all - s550 6 piston brembos are a DIRECT fit on our cars with the right parts! (05-14)
Question 2: 'Do I need a bigger Master reservoir or cylinder?'
Answer: No you do not
Question 3: 'Do I need to upgrade the brake lines?'
Answer: No you do not, but I highly recommend to do so to eliminate mushiness since you already there
Question 4: Fluid: My car is 5 speed TR3650 so i have to use DOT3
IMPORTANT INFORMATION: For this project you need:
s550 6 piston brembos - does not matter from what year
13-14 gt 500 15 inch rotors, DO NOT BUY S550 ROTORS, the caliper wont fit right and you will need washers
s550 6 piston brembo brake pads
Steel lines s197 for 05-14 - Recommending getting the ones with round fitting to avoid shaving corners off from rectangular one, same thing goes for oem lines - they will need to be shaved
BE aware of the wheel clearance, 17 and 18 will not clear the brakes - they are massive!
19s and 20s will (depending on the offset), spacers may be needed
My setup is
20x10/11 Velgen VF5
+33mm + 55mm, i think, might be wrong with offsets
I did not need to use spacers, also off topic, but with this setup you can run 265/35 fronts and 315/35 rears without rubbing Nitto nt555 fronts and invos rear
With that question out of the way, lets go into a part list!
Disclaimer: I got all my parts through Rock auto and those are links and names i will provide, but you can choose your supplier
Parts:
Rotors: RAYBESTOS 681047PER (High Performance) R-300 High Performance
Cost: 92$ per unit
Calipers:
Left: MOTORCRAFT BRCF431
Cost: 186$ + 50 core charge (refundable)
Right: MOTORCRAFT BRCF430
Pads: POWER STOP Z261792 {Z26-1792} (High Performance) Z26 Street Warrior
Cost: 73$
Lines: Power Stop BH00115
Cost: 108$ front and rear
Harware kit: 15-22 6 piston harware kit
Be aware - brakes wont come with pins for pads, you have to get the kit
Cost: give or take 20-25 bucks
This is all you need, Total: 757$ + tax,
857$ + tax if you don t return your old brakes.
Additional:
If you want to do the rears - the best way would be:
13-14 GT 500 rear rotors 14 inches
Adapter bracket to offset the caliper
Brake line kit from above
Use stock caliper and pads. You can go without a bracket but you will need to drop diff and a bunch of other parts and replace the hub, caliper mount and a bunch of other stuff (not worth it- go with bracket)
Hope this was helpful, brakes are great improvement over stock without spending an uncomfortable sum, let me know if you have any questions!
My setup is
20x10/11 Velgen VF5
Parts:
Cost: 92$ per unit
Calipers:
Cost: 73$
Additional:
