So I bought a 2006 v6 Convertible that had been sitting for over 2 years. I took out the starter and tested it at AutoZone with their test machine and it passed just fine and I got a new battery.
I took out the starter relay and made sure it was fine, and jumped the 30 and 87 pins on it and you can hear the starter click out but no spin so I’m pretty sure there’s a loose ground or I’m not getting enough voltage to the solenoid.
I’m pretty inexperienced when it comes to electrical issues and reading wiring diagrams and I’m not sure how much of a difference there is between the 4.0L V6 and the 4.6 GT wiring diagram because my engine bay I think is either missing another ground from negative battery terminal to the chassis or the one that is going to the positive terminal to chassis was placed wrong?
I’m also a bit confused as to what that rectangle metal thing on the red wire is that is covered in a red goo. Was that just a botched solder job?
How should I proceed? And if anyone had a picture of what their wiring setup looks like that would be really helpful.
(Also when doing the tests I clamped down the connectors to the terminals but the positive terminal doesn’t really have a way to snug it tight, I just kind of hammer it into place around the terminal)
![b29efb9efeb3dda30224cb2f65e178a0.jpg](/proxy.php?image=https%3A%2F%2Fuploads.tapatalk-cdn.com%2F20230811%2Fb29efb9efeb3dda30224cb2f65e178a0.jpg&hash=da6a9b7ff548ea6f2b98262796287175)
![f50b06e49d42a8844f9848f756343e79.jpg](/proxy.php?image=https%3A%2F%2Fuploads.tapatalk-cdn.com%2F20230811%2Ff50b06e49d42a8844f9848f756343e79.jpg&hash=a32e8e9d54b5ebe955351a6706d50322)
