luillo
So i decided to make a build thread to ensure i am not missing anything and entertain during the journey. There is so much options for these cars and it will take me some time to achieve my goal that it made sense to track any progress and plan accordingly.
Details are below and i will update it as i progress:
2013 GT500
Gray
Stock
Goal > To build the best 1/4 mile drag Shelby with the best street drivability possible. Looking for weight reduction, traction, and ultimately more powa!!!
Build Goal:
2013 GT500
Gray
Stock
Build Goal:
- Built 8.8 Rear End:
- 9" Housing Ends & Welded Tubes
- Strange Billet Main Caps
- 4.10 FRPP Gears
- TruTrac
- Moser 31 spline axles
- Shelby Diff Rear End Cover
- Suspension:
- BMR Adj UCA & Bracket
- BMR Upper Diff Bushing
- BMR LCA Relocators
- BMR Billet LCA
- BMR Adj Padnhard bar, Pandhard Support bar & Relocator Bracket
- BMR Radiator Supp & Sway Bar
- Vikings Crusaders Double Adj Front & Rear
- Transmission:
- Tremec T56 Magnum XL 2.97
- McLeod Clutch & Lightened Flywheel
- Shelby Clutch Fluid Reservoir
- Engine:
- Stainless Works 1-7/8 Long Tube Jet-Hot 2500 deg Titanium Coat
- Stainless Works Cat back
- JDM Built Short Block with Sleeves & Oil Pump
- Support items for Cam chain etc.
- Modular Head Shop Stage 2 Heads & Cams
- Lower Intake:
- Fischer Motorsport Hot Water bypass mod
- Induction Upgrade:
- Whipple 3.8L Gen 5
- Kenne Bell 168mm Mono Blade Throttle Body
- JLT 148 Super Big CAI
- Brakes:
- Baer SS4 Light Weight Front Brakes
- BPS Rear 15" Conversion Kit
- Exterior & Wheels:
- Shelby Wide Body Kit (Rear Only)
- Forgestar Custom Wheels (Daily Drive Wheel Setup)
- Front 19x8 or 19x7
- Rear 20x11 or 20x13
- Tires TBD
- Forgestar Drag Wheels or Welds (Track Only Wheels)
- Front 15x5
- Rear 15x10
- Tires TBD
- Black Mamba Super Snake Hood
- Carbon Fiber Doors & Trunk
- Optic Armor Windshield Front & Rear
