Need help finishing gauges wiring
DeadKevin
***posted this by accident in wrong 3.7 "year" forum***
I just added 3 Autometer gauges-Oil Temp, Oil Press, Volt. They are all grounded, check.
Now I need help with the 12V connection. Guy at shop said I could/should in-line wire straight to battery...is he correct?
Then the Ignition Switch tie in...is there a fuse tap in particular I should use, or what else should I do instead?
I've searched the forums and came close to an answer, but I'm pretty new to the add-a-fuse and gauges field...and pretty stupid too, so any help is greatly appreciated.
