For your time to be added to any of the lists, you will need the following:
1) timeslip--if you don't have it, unless you have video, forget it. If you only have video, please provide the 60', 1/8-mi and 1000' incrementals
2) The following vehicle information:
- Cubic inch displacement (CID) of engine
- Type of transmission (by model number)
- Size and Manufacturer of power adder, or N/A
- Pounds of Boost, of N2O shot (or both if applicable)
- Rear Gear ratio
- Make, type, and size of tire
3) Post two slips from the same day---shouldn't be a problem as rarely do you go to the track and make only one pass.
Continue to post your best ETs and timeslips here: http://www.s197forum.com/forum/showthread.php?t=7
- Rear Gear ratio
OUR RECORD HOLDERS
***JPC is the quickest and fastest Coyote 4V on this board. JPC runs a single 76/85 turbo, single power adder, no nitrous, and is the only car in the 7s. Read about his combo here: http://www.nmradigital.com/2014/01/22/justin-burcham-breaking-barriers-isnt-magic-nor-is-it-easy/
***GT RO is the quickest and fastest 3V on this board. Gerry runs a single 88mm turbo. Here is a video:
***JDCOON is the quickest and fastest 330 4V on this board. JD runs a 3.6LC Kenne Bell at 26 psi.
***JPC is the quickest and fastest N/A Coyote 4V.
***SPYDER7724 is the quickest and fastest N/A 3V car on this board-- a 334 cid 3V!!
To make the TOP 100 on this board, you have to be in the 10s!
1 car in the 7s
12 cars in the 8s
27 cars in the 9s
60 cars in the 10s
Below is the TOP 100. See other threads for specific rankings of 4V POWER ADDER, 4V N/A, 3V POWER ADDER, 3V N/A.
#9 Psfracer
![1378048_680077865356128_518054440_n.jpg~original](/proxy.php?image=http%3A%2F%2Fi410.photobucket.com%2Falbums%2Fpp183%2Fpsfracer%2FOTHER%2520STUFF%2F1378048_680077865356128_518054440_n.jpg%7Eoriginal&hash=6db32594a9d341e9d77c73d2bf503ee0)
![JDCoon.jpg~original](/proxy.php?image=http%3A%2F%2Fi410.photobucket.com%2Falbums%2Fpp183%2Fpsfracer%2FOTHER%2520STUFF%2FJDCoon.jpg%7Eoriginal&hash=2094494e64b03186410f1211b84030cc)
![JPCrecordholder.jpg](/proxy.php?image=http%3A%2F%2Fi410.photobucket.com%2Falbums%2Fpp183%2Fpsfracer%2FOTHER%2520STUFF%2FJPCrecordholder.jpg&hash=80f66b2c64f8a4fe41f571376d65db32)
![JPCrecordholderengine.jpg](/proxy.php?image=http%3A%2F%2Fi410.photobucket.com%2Falbums%2Fpp183%2Fpsfracer%2FOTHER%2520STUFF%2FJPCrecordholderengine.jpg&hash=926184a76443591fbb9a507e54e08822)
![IMG_2903JPG-1-1.jpg](/proxy.php?image=http%3A%2F%2Fi410.photobucket.com%2Falbums%2Fpp183%2Fpsfracer%2FIMG_2903JPG-1-1.jpg&hash=690f5de44b170495a5ebb8c2a3b3602d)
![54plusshaftTX009-1.jpg](/proxy.php?image=http%3A%2F%2Fi410.photobucket.com%2Falbums%2Fpp183%2Fpsfracer%2F54plusshaftTX009-1.jpg&hash=5c7f1901771bd32ef03e024f3cc88204)
1 car in the 7s
12 cars in the 8s
27 cars in the 9s
60 cars in the 10s
![S197Top10011092014P1.jpg~original](/proxy.php?image=http%3A%2F%2Fi410.photobucket.com%2Falbums%2Fpp183%2Fpsfracer%2FS197%2520forum%2520lists%2FS197Top10011092014P1.jpg%7Eoriginal&hash=a15384568e6d4432ab31a181acb68fcb)
![S197Top10011092014p2.jpg~original](/proxy.php?image=http%3A%2F%2Fi410.photobucket.com%2Falbums%2Fpp183%2Fpsfracer%2FS197%2520forum%2520lists%2FS197Top10011092014p2.jpg%7Eoriginal&hash=d7edcf0a2a95e24ca04f70a0c35afce6)
![Famoso2013web2.jpg](/proxy.php?image=http%3A%2F%2Fi410.photobucket.com%2Falbums%2Fpp183%2Fpsfracer%2FFamoso2013web2.jpg&hash=936505c483785e826704f4e261304b94)
#9 Psfracer
UPDATED 11/09/2014
