MrBhp
- Joined
- Sep 12, 2013
- Posts
- 1,275
- Reaction score
- 1,062
Those tires appear to be hooking well.
I have been giving that some thought and I may try some bracket or index events if that opportunity arises. I know Bradenton does have some regular bracket competition, perhaps once a month, and some of the guys there asking me the same question. I know that bracket racing is more complicated than it looks and consistency is a key factor, but also that choosing the right dial-in and monitoring your opponent as you make your way down the track can make the difference. I shouldn't say that I know, but rather, so I have heard. I think the guy who wins the Sportsman class at Bradenton most often is running a 15 second Fox body.So when are you are going to stop test and tune and start racing?
Shank style lug nuts are a pain but when you start getting into 1.5 60' times on a 4000 pound car, they start to matter.
Yes. The shank style lug nut spreads the load over the more of the wheel stud.I figured there was a reason why the shank style was in use, so I would assume there is some type of strength advantage?
It can work. It takes time to perfect the launch point.I thought DR's and stock manual tran's were not a good combo from the shock?
Just a quick Google search for NHRA lug nut rules 2023 will turn up the current information. I just download the book each season to see what may have changed.Do you have a new rule book? Last one i have is 2019.
Thanks! The car has responded well to the limited mods and the air was great that night. While I can't be certain that the weight reduction (100 lbs?) made that big a difference, it certainly seems to have contributed to the low ETs and higher trap speeds. Given my original hope to run high 12s, I am pretty excited to be running in the low 12s now.Nice!
The car seems to be doing its job. If you could improve your reaction time (or keep your RT close to the first pass), I bet you would do well. I am guessing you are shallow staging?So when are you are going to stop test and tune and start racing?
The car has exceeded my expectations, so it's definitely holding up its end. I agree, I certainly need to focus more on the tree once I'm stagged. I am shallow stagging in an attempt to get the lowest ET possible at this point, and I bet you know that from experience. I was planning to do some bracket racing in January, but they pushed that event off to March and have not schedule any bracket events between now and then. I think the track is focusing on more lucrative events, but I am not complaining if that keeps the track open. The staff at Bradenton Motorsports Park does a tremendous job on the track, even for test & tune events, and I am thankful for that.The car seems to be doing its job. If you could improve your reaction time (or keep your RT close to the first pass), I bet you would do well. I am guessing you are shallow staging?
This past weekend, March 16 - 17, Bradenton Motorsports Park in Florida hosted two NHRA bracket racing events. Each day was considered a separate event. I competed in the Sportsman class, which included ETs from 11.0 to 20.0. I was fortunate to have some coaching from an experienced racer who I have gotten to know from Test & Tune events. He also competes in a mostly stock 2014 Mustang GT. Although I was certainly intimidated, given my "first timer" status, his detailed explanations of the registration process and the general flow of the day went a long way to reduce my anxiety. Each day's event started with about 25-30 cars in the Sportsman class. At around 9:00 am we had our time trial runs, followed by the first round just before 12:00 pm. First round losers had the option of a "buy-back" to continue racing (eligible to win cash, but not receive points). I know this is already a long post, so I will follow-up with each day's slips and I description of how my runs went.The car seems to be doing its job. If you could improve your reaction time (or keep your RT close to the first pass), I bet you would do well. I am guessing you are shallow staging?
