1950StangJump$
- Joined
- Apr 1, 2010
- Posts
- 966
- Reaction score
- 108
My brake fluid reservoir in my 08 GT has always sat a little crooked from the factory. While I admit to being OCD, the fact it is leaning a touch to the side is actually a little bit of a mechanical issue now - it is very close to the throttle body of my new blower.
There are two 13mm bolts and a gasket holding the tank and support arm to the booster. Is that gasket holding back fluid? If so, I won't mess with it. If not, I'll loosen the two bolts and see if there is just enough wiggle to straighten up everything and tighten back down.
