Mustang had been parked for a week and i had left my old phone plugged in to a charger in the center console. Tried to start and of course the battery was dead. Throw charger on it for a bit, enough to start the car to move it out of the garage. This is where I may have f'd up. I unplugged the charger while it was still connected to the battery. The made a couple of beeps and lit up the display like it does when first powered up but immediately went dark the a second later does it again. I then moved the car out and that's when I noticed the "Check Charging System" message. After I finish my work on the garage, I move the car back in and hook it up and fully charge the battery. Tonight I go out and take the alternator off (nice Denso model I got from DOB) and put my original alternator on and everything works. So yes, you can kill an alternator with a battery charger if you screw the pooch like I did.
Backstory: the original alternator had died a few years ago, so I thought hey, let's get one of the PA alternators. Well that thing died within a week, burning the battery cable in the process. So I took my original alternator to a local shop for a rebuild (one year warranty). I was working great for 3+ years until I bought the Denso from DOB (higher output that my stock one).
The Denso would probably still be going strong if I didn't kill it with my stupidity. I think I will take it to the shop that did my original one for repair.
Lesson learned...
Lesson learned...
