TGR96
el blanco nino
OK guys, I have searched a few forums, the interwebz, and I have only found a little bit of info regarding the swap from the base model door panels to the premium panels with the door speakers (subs?). Has anyone on here done this, or have an idea on what it involves? I assume that it isn't plug and play, since the premium panels have additional speakers that the base car does not.
It looks like I will need at least an amp to power the door subs. I have found factory Ford amps from these cars on eBay for around $20. Will I need anything else? I assume the wiring connectors, obviously.
Any help would be appreciated. And for the record, I am not an audiophile, and I have only done a very little bit as far as wiring car audio, and it was pretty much a simple head unit and speaker replacement. I just want a little better sound than the factory base model stereo. So be gentle...
And as the thread title says...the car is a 2013 GT.
TIA
TIA
