As some of you may recall, I've had a myriad of fuel delivery problems. After the car was tuned in May of 2012 by Pro Dyno the car ran great - as far as I can remember. Shortly after, I had the fuel hose on the hat rupture and blow out. Since then, I also had the liner in the fuel line in the engine bay become dis-bonded and cause the fuel rail to essentially be plugged up as documented here:
http://www.s197forum.com/forum/showthread.php?t=97070
While the car runs better now that those issues have been resolved, it still runs lean throughout the whole RPM band and especially in first gear. The car will stumble under various loads- mostly from a stop, rough idle, gas mileage sucks (210ish), and overall the car feels like a total dog. Throttle response is nonexistent and I have to dump the clutch to even chirp the tires from a stop. I feel like a positive displacement blown, 450 whp V8 shouldn't drive this way. As a friend put it: "it definitely feels like a good running small block, but not a 500 hp supercharged monster."
My symptoms say to me that I have clogged/bad fuel injector(s). The car has loads of power when its still cold but once it heats up, it falls on its face. My thinking is that the problem I had with the fuel line post fuel filter allowed some debris/glue/whatever to cause a blockage in one or more of my injectors. This would explain the stumbling, idle, and poor gas mileage. The car sees that its running lean once it warms up and pulls timing hence the lack of power everywhere.
My notable mods are as follows:
DOB manifold with stock GT500 Eaton blower
GT500 47 lb/hr injectors
Walbro 405 fuel pump
Offroad x pipe
stock mufflers
TR6060
If it's not the injectors, I suspect the tune. I only have enough money right now to get a tune done by Lito or to get new injectors so I'm looking for advice here. Any other suggestions?
Offroad x pipe
stock mufflers
TR6060
