This illustrates OEM (right) and ARP (left) part number 250-3003 Ring Gear bolts.
The install instructions from Ford Racing and those provided by ARP are different.
Ford Instructions – apply 1/8 bead of Loctite 638 (red) around the rear face of the ring gear and tighten to 97-102 lb-ft. (no Loctite called for on bolt threads)
ARP Instructions – apply Loctite 242 (blue) to bolt threads and ARP Assembly Lube under the bolt heads and tighten to 85 ft-lbs.
What instructions should I follow or what is recommended?
