csracing
Are all 4R70W transmissions the same? Meaning, if I have one that came out of a 2WD truck with a 4.6L can I rebuild it and expect to use it in a S197?
I thought the truck ones were slightly longer
Think a 4r70 can hold 800 to 900 and be reliable and not take a shit?
Yes
We have one in a 900rwhp Coyote Swapped Lincoln that lives at the track all weekend every weekend.
how much was just the trans to do it and who built it?Been thinking a th400 will be half the price as a 4r so been on the fence?
All 4R70W and 4R75E have same gear ratios. The F150 4R70w and the Mustang 4R70W are the same length. Its the Lincoln and some big body cars that used the longer tailshaft.
I have built and swapped several between Mustang and F150. I currently have a 2003 Mach1 4R75E in my 2001 F150 Supercrew.
The diameter is same on all 4R70W and 4R75W 2wd applications the difference is AOD used a smaller hole/bushing in rear tailhousing.
The best trans to build off of is a 5.4L F150 from 2003.
5.4L applications have better pump pressure boost valve and some beter components and in 2003 they did a J-mod in the transmissions.
We built it ourselves parts were about $1,000 plus cost of a converter of course.
Thanks man. cause I have got a th400 swap priced and a 4r70w swap price and the th400 is cheaper but 2,000$ so Im just on the fence about what to do really. And not sure where to get the 4r built to hold 900 and be reliable/
