Garage Tools
JEWC_Motorsports
S197 Junkie
Texas
Does anyone have a parts washer and chemical they recommend? Also, does anyone have a hot tank at home, home made or store bought? What do you recommend? Im currently using a drum filled with water and a simple green aircraft solution heated by my kerosene jet. It stinks and kerosene isn't cheap. Id rather have something i can run off 110v. The reason for this is im getting into building engines and i am slowly buying the things i need to do it all in house.
dark steed
Resident noob
Winder, GA
My dad has had an old Safety-Kleen parts washer with a 20 gallon drum for decades. After the solvent ran out he just used mineral spirits
Tools I think of that are needed when building engines:micrometers, cylinder boring setup, cylinder hones, valve grinder, tools to do guides and seats for heads, crank grinder, just to name a few.Than a parts washer and hottank.
There are safety klean "style" parts washers fairly cheap. A drum, a pump, a tub and light.
JEWC_Motorsports
S197 Junkie
Texas
I have a turntable washer but it SUCKS. Got it free and my pressure washer does a better job of cleaning. I have a valve grinder, mics, hones, and the small tools. I am looking at a belt polisher, crank grinder, and a line bore.
Good luck on your tool hunt. Im getting lazy in my old age. Last "build" for me was a complete teardown and inspection of my 91 5.0. few minor items replaced, and reassembly.
I didnt even pull the pan off the junkyard pull coyote, while it was hanging from the hoist. Just dropped it in. lol
oldVOR
Northern Virginia
I have a Safety Kleen parts washer that sits on a 30 gallon steel drum and use either the Safety Kleen solvent or Gunk solvent. It's probably 25 years old at this point and works as it did when it was new. I've only had to replace light bulbs, solvent and brushes.
