Sounds like one of your HVAC blend door actuators is going out. This happened on our 2011, and is a fairly common problem. Depending on where in the dash the noise is coming from, you might be able to figure out which actuator is bad. Changing them out is pretty straight forward, but some of the bolts are a p.i.t.a to get to.
