DieHarder
- Joined
- Nov 9, 2019
- Posts
- 1,495
- Reaction score
- 782
Car was running fine and battery went dead. Tried to start it; then jump but nothing. Recharged the battery. Now the car won't crank. Has a Ford remote-start security system which was an option back in the day. Key fob doesn't lock/unlock the doors or do anything now. Checked the fob battery (12.4 vdc).
Tried two different main batteries - same result but unsure whether I can trust either one. When I connect battery negative the horn blares a constant tone (not the usual warble - on for a second/off for a second and the fob won't silence it). One red idiot light on the dash in the lower right that looks like a car & lock which flashes on and off about two seconds or so in length and goes out when I put the key in.
My SCT X4 doesn't show any codes. Not sure if PATS is locked out or something else. When I go KOEO lights; interior; radio work but no crank. Checked ignition circuit fuse #68 - good.
Is there a procedure to reset the alarm/reinitialize or reset PATS? Tried looking something up online. Found one procedure that supposed to clear the alarm by disconnecting the battery and going KOEO for 5 mins and then taking the key out of the ignition; locking the doors; reinserting the key and starting the engine. First time didn't work in my case. Will try it again.
Worst case I have another complete security system from the same year brand new in the box though not sure if I could do more harm than good with it. All I can say right now is the car won't crank and the horn continues to blare non-stop.
Any recommendations for procedures/systems to check? Thoughts?
